現在的時間是 2026-06-22, 22:43
發表新文章 回覆主題  [ 5 篇文章 ]
文章發表於 : 2012-10-01, 15:45
文章: 2179
1. http://www.redmondpie.com/how-to-instal ... -tutorial/
2. (初階版)讓PC也能安裝蘋果系統的好幫手:幸運草
3. (進階版)讓PC也能安裝蘋果系統的好幫手:幸運草
4. (高階版)讓PC也能安裝蘋果系統的好幫手:幸運草
文章發表於 : 2012-10-20, 16:55
文章: 2179
UniBeast: Install OS X Mountain Lion on Any Supported Intel-based PC
==> Good Guide
文章發表於 : 2012-11-12, 11:32
文章: 2179
黑蘋果安裝Mountain Lion 10.8(2012.08.05補充內顯修正)
HoboMac - The Cheapest Hackintosh
文章發表於 : 2013-02-19, 11:36
文章: 2179
How to install OS X Mountain Lion in Virtualbox with iAtkos
iAtkos method for installing Mountain Lion on Virtualbox
文章發表於 : 2013-02-21, 12:29
文章: 2179
First, open the Command Prompt in Windows (make sure you are logged into an Administrator account on Windows). You can do this by opening the Start Menu, and typing "command prompt" into the Start Menu search bar. Then, type the following command into the Command Prompt.
cd "C:\Program Files\Oracle\Virtualbox"
This command will change the focus of the Command Prompt to the program folder for Virtualbox (if you installed Virtualbox somewhere different, then change the command to wherever you installed it). Next, type in this command:
vboxmanage setextradata "Name of virtual machine" "CustomVideoMode1" "1920x1080x32"
This command activates "vboxmanage", a command-line program included with Virtualbox that allows you to edit the properties of your virtual machine, including its built-in resolutions. Replace "Name of virtual machine" with the name of your virtual machine (in the screenshot below, my virtual machine is named "Mountain Mac 2"). Replace "1920x1080x32" with whatever resolution you're using.
